It is currently Thu Jul 31, 2025 8:43 pm
PostPosted: Thu Oct 16, 2008 9:06 am
First name: Ron
Last Name: Y
I would like to know If there is a particular masking tape that I can use to mask around the bridge, to scrape off the finish, and not cause any damage. The guitar was finished with Tru-Oil. Thanks in advance for all responses.
Ron M.
PostPosted: Thu Oct 16, 2008 10:01 am
First name: Jim Howell
I think that the safest tape to use is 3M drafting tape. You can still get it at most Michael's and also check out the Yellow pages for a Survey/Map supply company. They will have it in a variety of widths.
You can also take blue or green masking tape and stick it to your jeans prior to using it on a guitar to take some of the tack out of it. Regardless of what you use, don't leave it on for too long.
Jim Howell
Charlotte, NC
PostPosted: Thu Oct 16, 2008 1:19 pm
Not all blue tapes are alike. The Scotch 2090 that seems to be more common in hardware stores has a crepe backing that will leave impressions in a fresh finish, and it also leaves adhesive residue. Scotch 2080 (not that hard to find; paint stores usually have it) has a flatter backing, leaves less residue, and is safe for longer times. But it's still a good idea to dull the tack by sticking to your shirt first, and get it off the guitar as soon as possible (couple days max). You may need to buff a bit to restore the surface. 2080 is what I use.
The green Scotch is supposed to be the most safe for lacquer (nothing in its adhesive is a solvent for lacquer, unlike the others), but it also has a very high tack. I haven't tried it yet. There is also a yellow low tack Scotch, but it's hard to find and I don't know if it's lacquer safe. I know you used Tru-Oil, but I don't know which solvents will attack a cured tru-oil finish.
PostPosted: Thu Oct 16, 2008 1:40 pm
First name: Ron
Last Name: Y
Thanks jhowell and Howard for your help.
Ron M.
PostPosted: Thu Oct 16, 2008 3:19 pm
First name: Chuck
Last Name: Gilbert
Duck brand makes a purple painters tape that has the least amount of tack that I've seen among the various painters tapes. I get it at my local hardware store. However, there is a warning inside the roll to avoid using it on lacquer. I have, but only for short periods and I haven't had any problems.
I have used the green Scotch and do not like it because it is way too sticky.
Chuck
"To live a creative life, we must lose our fear of being wrong"
- Joseph Chilton Pearce
